Yet Another Led Question
Old May 11, 2005 | 02:29 PM
NewfieShark's Avatar
im in the process of replacing my interior dash lights with blue leds. i was wondering about the switches with on/off lights (the lights that turn on/off when the switch is turned on/off like the a/c, fog, rear def.). so far i've just been removing the stock light, and running a led where i wanted it, and wire it to a different location. but those on/off lights, will i have to solder a led where the old light was? or is there a different wire running to those lights?
and if i have to solder it to the origonal location, will i need a resistor, and where would it go? any help would be great. thanks!
Old May 11, 2005 | 02:35 PM
KayJai's Avatar
QUOTE (NewfieShark @ May 11 2005, 03:29 PM)
YES
No resistor needed.
Do a search here or on the archives, I know I posted something up.
If not Tibby01 posted something tooo
Old May 11, 2005 | 04:34 PM
http://www.rdtiburon.com/index.php?s...7584&hl=switch
and
http://www.rdtiburon.com/index.php?s...2433&hl=switch
Old May 11, 2005 | 08:09 PM
QUOTE (KayJai @ May 11 2005, 08:35 PM)
No resistor needed.
are you sure? from what i read above i will need resistors. thanks again for all the help.
Old May 11, 2005 | 08:56 PM
if you are replacing leds, then you dont need a resistor b/c there is already one in the circuit for the stock led. anytime you replace a bulb though, you will need a resistor. there are only two, sometimes 3 stock leds...the activation lights for the a/c and recirc switch.
