Wiring Diagram For '01 Tiburon.
Hey guys. Im installing a Presteige Alarm in my girlfreinds 01 Tiburon. Im hav ing trouble locating a couple wires & cant seem to find anybody who knows. I need to know the color & location of the following wires.
Door Trigger, basically whatever wire that goes to the dash that tells you the doors are open.
Rear hatch trigger, same thing, which ever wire goes to the dash.
And a Safe connection to hookup the parking light wire.
If anyone knows, that be great. Thanks guys...
Hyundai Tiburon 2001
Start: YELLOW/RED to gray IGNITION SWITCH HARNESS
Ignition #1: BLACK/WHITE to brown IGNITION SWITCH HARNESS
Constant +12 Volts: BLUE/BLACK IGNITION SWITCH HARNESS
Accessory # 2: wht/blu to pink IGNITION SWITCH HARNESS
Accessory: red/wht to grn/wht IGNITION SWITCH HARNESS
Brake Light: DK. GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Tach Signal: YELLOW OR BROWN blue 20 pin plug, pin 1
Parking Lights: GREEN/WHITE (+) gray 20 pin plug, pin 11
Notes: The plug is just below the cross member beam under the driver side dash. Can also find tach at the ignition coil on the driver side of the engine, use either the green or white wire.
The plug is below the cross member beam under the driver side dash.
Starter Kill: YELLOW/RED IGNITION SWITCH HARNESS
Ignition +12 Volts: BLACK/WHITE IGNITION SWITCH HARNESS
Dome Lights/Superv: BLACK/WHITE (-) DRIVER'S KICK PANEL **
OEM Horn: BLACK/RED (-) STEERING COLUMN HARNESS
Power Lock: ADD ACTUATORS *
Power Unlock: ADD ACTUATORS *
Trunk Release: N/A
Alarm Input Wire: BLACK/WHITE (-) DRIVER'S KICK PANEL **
BROWN/RED (-) Wire Is Trunk Pin Located In Driver's Kick Panel.
Trunk Release: N/A
Vehicle: 01 Tiburon
here ya go!
http://www.commandocaralarms.com/wir...yundai/Tiburon
btw, sometimes the wire colors can be confusing... make sure you utilize your multimeter and you'll be fine
hopefully that will help
btw, from where in canada are you from?
Cool, thansk guys. Anyone know what the Alrarm Input Wire ( Black/White ) is? Is that the door trigger wire. Ill try & locate the green/white wire, I did lasttime & came to a dead end.
just multimeter everything, as said above.
i was looking at schematics and the wiring diagrams available on the 12 volt and i still had a b**** of a time finding the right wires, but it all works. id tell you exactly which ones were which but i cant remember, sorry.
