Window Motor
Old Apr 4, 2008 | 07:47 AM
Trevor Hall's Avatar
Anyone know how to get it out or work on it?? I looked on the Webtech,, do i have to take the whole assembly out of the door just to work on it? The passenger side window got stuck halfway up,, the motor just spins,, the cable won't grab mad.gif Any way of fixing this? or will i have to get a whole new assy?
Old Apr 4, 2008 | 08:02 AM
StrikeEagle's Avatar
Take off the door panel and you can have access to it. Beyond that, it's hard to diagnose exactly what needs to be replaced or repaired.
Old Apr 4, 2008 | 08:07 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
http://www.rdtiburon.com/index.php?showtop...regulator\
Old Apr 4, 2008 | 08:50 AM
Probably need a whole new assembly my man. Take off yourdoor panel and look at everything really good.
I've got a spare motor if you need one, MOTOR only.
Old Apr 4, 2008 | 09:11 AM
Moved to Interior....
My sister has had several problems with her window/lock motors on her GK.
I'd pop the switch panel up (carefully not to scrape it) and make sure the wires are all tight and secure before going through the trouble of messing with the motor. It could be a loose wire - what problems are you having? Just flat out won't work? slow?
Old Apr 4, 2008 | 11:06 AM
rallyman's Avatar
If the motor spins everytime you press the window switch the motor, switch and wiring must be fine. It's probably just the window regulator that is broken. You can get them on Ebay for under $100 I believe. 'Four Green Auto' is a good Ebay vendor for OEM parts. 'Mirine' is good too.
