What size power & ground wires
Old Jun 10, 2010 | 08:14 AM
Cereal Killer's Avatar
Vehicle: 2005 V6 Tib
Default What size power & ground wires
What size cables do you guys all run for your amps? Im thinking about getting 0 gauge to run my 2 channel kicker, but thinking that may be over board. Im sure 4 gauge would probably be enough.
Also is it true that what ever size my power cable is, the ground wire should be the same too?
Old Jun 10, 2010 | 08:23 AM
342Four's Avatar
Vehicle: '97 X3
bigger the better
what sort of wattage is the amp?
i would recommend same size ground as power
if its a big amp i would also recommend upgrading ur battery grounds aswell
Old Jun 10, 2010 | 08:37 AM
always match your ground and power cable
Old Jun 10, 2010 | 04:13 PM
It's impossible to properly answer the sizing question without a wattage.
