What Should I Do With This?
Since I am home for the holidays, I was cleaning my room and the going through my boxes today, I found this:
It was initially suppose to be for a fan grill for the computer i never bought. Anyways, suddely an idea to came to me that I could use it for my car.. problem is the idea kind of died there, I dont know to use it to enchance my car. I currently dont have any lightings internally or externally. I dont care where I use it, since it is just lying around, so any ideas would be great, even uder the hood if you can come up with some thing wink1.gif
Shad
Shad
lol, make a projector for it and tie it into your alarm system. Have it project it on the wall in front of the car when the alarm goes off. That will make a thief run. wink1.gif
i was going to use those computer rice fan grills for a buddies sub/amp enclosure in the back. the idea ended there when i realized i just dont have the time or patience to pull off ridiculous fancy shit like tha.t
Oooh for my amp/sub, i can attach it onto my sub, now thats 1 good idea so far.
tie it into the vehicle security system and put it inside the windshield.
Do a dancing LED setup and mount it straight up and down on the dash in the center.
Mount it on top of the steering wheel cover.
Put it on the floor in the center of your trunk or behind the center console.
Mount it to the sunroof so you can display it when you open the sunroof.
Get two of them and replace the LED with red, use them for rear marker lights in your air dams on the back of the car.
Hook it to a pressure sensor you welded into your intake manifold and when it lights up when you're using your naawz that's your "danger to manifold" indicator.
