What gauge wire?
I hooked everything up using the 10 gauge from my old amp and it seems to be working okay, what will happen if I don't replace it with the lower gauge wire...? BTW it is 2 x 80 W RMS in response to MADTIB.
QUOTE (jToIeB)
if its too small a wire you will lose voltage to ur amp(bc there is more resistance)...if its very small the wire could heat up(which wastes energy) and worst case scenario cause a fire...not good results..dont be cheap...its not worth it...
If it's only 2 X 80Wrms, then you don't need tobig of a ga.What does the owners manual suggest? My guess is a 10 or 8ga. My suggestion would be the 8.In my opinion it's better to use a little larger then what is called for.That way there is NO question, and if you later deceide to add another amp, then your main cable will probably already suffice.
EDIT*****
What brand amp is it? Just wondering,cause I don't see where the hell they get 1600W from????? You say it's 2 X 80Wrms, so assuming it's 2 ohm stable,then it will do about 160Wrms X 2 @ 2ohms.That's a total of about 320Wrms.Peak value of that is 400 and something.......Peak to Peak is 800 and something.So,WTF?? They must have rated that waaay beyond the actual usable power.
EDIT*****
Im assuming another zero was supposed to be at the end there. And if its 800 RMS I would think a 4 gauge wire would be great. My amp I have right now is only about 500 Watts RMS and im using 8 gauge so Id definately go bigger wire for the bigger amp
QUOTE (Ericy321)
Nope, it says 80 RMS... and the 1600 is actually just the max output of 4x400 so I kinda got screwed becuz it just said that it was 1600 Watts on e-bay. I'm thinkin I'll just switch out the 10 gauge with my 8 and then when I add on later it should still be alright.
