Vent Haloz Relay
Old Apr 17, 2007 | 02:48 PM
mr_jeckel's Avatar
I was just installing the Vent Haloz and was wondering if the relay is really needed. I know that the relay is basically a switch controlled by a power source. Since the LED's consume so little power, wouldn't it just be easier to connect the Haloz to a 12V power source that turns on with the illumination?
Old Apr 17, 2007 | 03:55 PM
zoned019's Avatar
Vehicle: 97 Tib
Not needed at all. But, I do suggest that you install an in-line fuse from the main power source going out to all your haloz. I had it blow on me once or twice while messing around with stuff, and if I wouldn't have had it they all would have burnt out.
Old Apr 17, 2007 | 04:20 PM
ya a relay isnt needed for them. 12v will be fin. as mentioned, be sure to fuse the power wire
Old Apr 17, 2007 | 04:43 PM
mr_jeckel's Avatar
Thats great. I have a power block installed below the head unit area with plenty of connections. It is already fused so I should be all set. Thanks for the quick response guys!
Old Apr 17, 2007 | 07:40 PM
the wire is already fused. Just tap power from the lighting system. Green/white and green/black.
green/white and green/black combo will allow you to dim them. Green/white and ground will just turn them on when the lights go on. There is no green/black in the door, you may want to run an extra wire.
