Trouble with climate control! help removing the dashboard
Old Aug 11, 2004 | 02:44 AM
memphisraines's Avatar
Default Re: Tons Of Stuff For Sale, Stock Parts, CAI, other stuff...
Hi!
I need help. I have to remove my dashboard because I think the switch for switching where the air should come out of my dashboard (window, feet, ...) doesn't work and I have to replace it.
The other possibility is that the little elektroengines do not work.
Does anybody of you have a similar problem?
Maybe you can send me some pictures how to remove my dashboard.
It's a 2000 tiburon. the one with the round front lights.
yours,
David
Old Aug 11, 2004 | 03:08 AM
javageek's Avatar
Default Trouble with climate control! help removing the dashboard
Welcome to the site! Hold tight and someone with a second gen will answer you. In the future, edit your post rather than posting again. (Double Post)
Old Aug 11, 2004 | 08:37 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
Default 97 Eyelids?
although there are things in this link that you dont have to do (remove steering wheel) you should be able to figure it out by going to http://www.hmaservice.com/webtech/iindex.a...id=12232#_12232
Webtech is our freind. use it. Tibby01 swears by it. its his (and our) bible
Old Aug 11, 2004 | 08:51 AM
Default Re: Trouble with climate control! help removing the dashboar
Can you please update your location?
Aut is an unknown abbreviation for us.
Old Aug 11, 2004 | 08:52 AM
use the link posted above, ONLY USE steps 4, 5, and 9. The others are not needed.
