Streering wheel hub?
Vehicle: Hyosung GT650
I'm getting a new wheel from Santa and I was looking at wheel hubs and have a Q.
Does an RD1 use the same hub as an SCoupe :?:
On K-Spec they list this size; H2 - Tiburon, Turbulence, Avante, Elantra, Soupe.
I assume that they all use the same 1, but want to be sure.
If the H2= Tiburon, Turbulence, Avante, Elantra, and Soupe then yes I would assume you need an H2 and David just forgot to put the C in there smile.gif .
QUOTE (insomnia)
That doesn't answer my question mang.
Seeing as how you were looking for a steering wheel hub for an scoupe.
I thought I'd direct you to this post cause there is a member on this forum who's selling a hub.
If you're set on the one kspec sells, yes it looks like the H2 is what you need. If you feel uncertain email Kspec and ask them directly. Or you could post in the kspec section as it's a product inquiry.
Just out of curiousity, what steering wheel did you get?
This will fit any year Elantra, 91-94 Scoup/Excel, 97-01 Tibs.
QUOTE (insomnia)
Haven't got the wheel yet. Santa is bringing me a flat bottom ("D" shape) wheel.
I personally would like to know of the mitsu EVO8 wheel will fit.... I may have to see about buying the old wheel from TCs black tib.. I do not need the airbag, just the hub.
I'm using an auto-tecnica hub in my car, just look a hub with will fit a e/lantra of the same year and I'm pretty sure it should it. But then maybe I got lucky.
This is for the universial hub/spacer that they produce Part No: 507146, I'd try and find out what mine is but my car is in a differenct state
