Stereo Write Up Needed
Old Jul 10, 2005 | 10:12 PM
JL_TIB's Avatar
so i did the serch thing but found nothing
can anyone help me out
basicly i want to put my infinity 6.5s from my celica in my doors of my 00 tib
as well as my pioneer head unit
i need to know how to remove my stock head unit which is a combo tape/cd player
also in order for me to install my infinitys in the doors can i take the grill cover off or do i need to take the door panel off
also how can i access the rear speakers, do the grills come off or what?
Old Jul 10, 2005 | 10:29 PM
fonseca's Avatar
The 6.5s should fit, but they may be a tad small. Easy to mount them even if they are with backstrap or the screw brackets that should have come with them. You have to remove the door panel, not the grill. Plenty of discussions here on how to do that.
Once you pull your double DIN deck, you will either need a single DIN fascia, or an install kit (such as one by Metra). A new fascia would look nicer. There is also a bracket that the Hyundai deck rests on, you can move that up higher to support your single DIN unit.
The rear grills pop off, try using a table knife.
Old Jul 10, 2005 | 10:38 PM
mb1604's Avatar
6.5 wont work unless u make custom mounts im pretty sure of. stock size up front is 6.75
Old Jul 10, 2005 | 10:41 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
QUOTE (JL_TIB @ Jul 11 2005, 12:12 AM)
take off shift knob
pull up on the shift plate to take that off
pull out on center console (near ashtray) to get to the stereo.
the stereo itself is only held in w/ 4 screws
real easy
Old Jul 10, 2005 | 10:44 PM
JL_TIB's Avatar
great, and the infinitys sounded so well
guess ill get new speakers or get my friend to make me an adapter, may go with adapter, its cheaper
yeah ill probally will get a single din bezel from the junkyard or ebay
thanks
btw does the shift knob on the rd2 just unskrew cause i tried that earlier today to put my other knob on and it wouldnt come off
Old Jul 10, 2005 | 10:53 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
yes it does. just put some sack into it. haha
and for the stereo, here are some pics:
pull up
pull out
then you see the 4 screws for the radio
Old Jul 10, 2005 | 10:56 PM
JL_TIB's Avatar
kool thanks that helps alot
Old Jul 10, 2005 | 11:01 PM
fonseca's Avatar
Like I said, just use backstrap or screw brackets in the proper size and they will install securely.
You could make an adapter ring, but that's overkill IMO for such a small gap.
Old Jul 10, 2005 | 11:13 PM
JL_TIB's Avatar
k
ill try to put the things in tomarrow if everything goes well
im just forever busy
lets see work form 7am-3...shit i need to go to bed
need to take tib i just got friday and go get the brakes fixed as well as other things
then all tuesday fix the celica....headgasket and replace all 4 brake lines
theres just not enough time in the day
Old Jul 11, 2005 | 12:11 AM
6.5's will fit fine in the front, you just have to bend the mount a bit for the screws to hit.
