steering wheel switch?
Old Jan 15, 2005 | 02:04 PM
MasterJ51503's Avatar
Default steering wheel switch?
does anyone have a switch to interior lighting on their steering wheel? trying to figure this out, plz help.
Old Jan 15, 2005 | 02:07 PM
No, but if you are talking about trying to set up some switches for your aftermarket interior lighting, try the Racerboy shifter. I've got one. Not bad at all.
Old Jan 15, 2005 | 03:42 PM
on the actual wheel would be hard as shit, because it has some super cool information transmitter thing so it can turn and not worry about messing up wires.
if you can figure out how to make it work witout having a HUGE wire so it has enough slack to turn a couple times, then you sir, are a genious.
now if you are talking about mounting a switch on the little steering column panel(or somewhere else past the "hub' transmitter thing), or using the horn button as a switch, then that we can talk about.
Old Jan 19, 2005 | 01:43 PM
injected's Avatar
I thought replacing a steering wheel with an airbar was illegal(canada)
Old Jan 19, 2005 | 01:58 PM
UltraTibby's Avatar
Yes it is illegal in the states. But so is removing your cat when you put headers on. I have an aftermarket steering wheel on the car and am really not all that worried about it laugh.gif:
Old Jan 19, 2005 | 03:52 PM
QUOTE (tibby01)
on the actual wheel would be hard as ****, because it has some super cool information transmitter thing so it can turn and not worry about messing up wires.
Actually.. it only has four connections. Two wires for the airbag and two for the horn. If it is like every other wheel I have seen off of the car, it has a couple of sliding rings and a roller connector. The rings are on either the column or the wheel and the connecton on it's opposite... very simple.
