Steering Wheel Removal Help
I am currently trying to remove my steering wheel, but the thing wont come off. I removed the 22mm bolt and got the harness off, but the wheel is not even budging.....any ideas why??? We already tried WD-40. 02.gif
The first time I took mine off it just pulled off by hand. The second time I had to use a puller. I actually used a large pulley puller but it all works the same.
thanks for your help. i was thinking that for some reason there was a bolt that i might be missing...but it finally came loose. thanks for the help again! i appreciate it so much! wink1.gif
holy crap, i didnt mention the steering wheel puller in my pm to you, did i?
its like 10 bucks at autozone. just be careful threading in the "puller" bolts. the metal in the steering wheel is soft.
http://www.rdtiburon.com/index.php?showtop...=steering+wheel
lol no you forgot to mention that part and i thought that maybe there was another bolt that was still in there because it was so hard to get off. the wheel isn't on yet, however, but yes i'm using the momo adapter. as soon as it's on there, i'll post some pics up and let you know how it is wink1.gif
