Short Shifter on RD2
Old Jul 20, 2011 | 09:55 PM
99sharkbmr's Avatar
Vehicle: 1999 hyundai tiburon turbo/ 2001 Tiburon(sold)
Default Short Shifter on RD2
On last 2 rd2's we have had when install short shifters in them, 1st gear is rubbing way up at the top/.left part of the circle. Is there special short shifter out there for 2001 Tib or has anyone done some sort of mod. My son has a 99 Tib and he has no problems
Thanks
Old Jul 20, 2011 | 11:51 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
No but more than likely it isnt the shifter, we have really sloppy shifter feel do you Really soft bushing!
You best bet is to look down at the trans, replace the stock bushing on the cable with aluminium, or maybe some hard plastics!
It feels like a totally diffrent car with a nice firm shifter, in my case it was just bushings in the cables, hopefully it will be the same for you!
Old Jul 22, 2011 | 10:35 AM
99sharkbmr's Avatar
not the bushing, on both 2001's they were good. Funny thing is on 99 Tib my son has he has no problems?
Old Jul 22, 2011 | 10:51 AM
StrikeEagle's Avatar
You have to adjust the cable length. Right near the base of the shifter there are the 2 cables going to the tranny. There are adjustment threads and nuts on there, if I remember right. Simply adjust them so your shifter isn't hitting in the 1st gear position.
Should be about a 5-10min fix with one single wrench.
The bushing is only for slop in the shifter. If yours are good, then great. I added some plumbing tape (white tape) in 2 or 3 spots around the shifter bushings. Did it about 4 years ago and got rid of virtually all the slop. Now it's a tad more loose, but nothing like what it used to be.
Old Jul 22, 2011 | 02:53 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
i had the same problem w/ my rside shifter but i ended up making my own shifter w/ a thinner shaft and i no longer have that problem.
