Running Wires
Old Jul 16, 2005 | 12:57 PM
domi's Avatar
Vehicle: 1999/Tiburon/RD1
I'm a little confused how to run the wires from my battery to the inside of the car.
I did do a search, but I only came across one where you have to cut a little whole in some sort of rubber thingie right behind the engine.
I have seen several tib's where the powercable runs into the fender
It looks much nicer this way and it doesn't take up much room in the engine bay.
Where does the cable takes his way into the cabin?
And how do I get it there.
Is there a way without removing anything from the car itself?
Old Jul 16, 2005 | 01:25 PM
zoned019's Avatar
Vehicle: 97 Tib
There's a DIY on how to run through the firewall .. you are hooking up a stereo system I'm assuming?
Old Jul 16, 2005 | 04:53 PM
domi's Avatar
Yes I am
Old Jul 16, 2005 | 06:09 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Put your wire through the fender, there is a hole near the battery that goes to the fender, once in the fender go up over the wheel and along the side where the door is is a small rubber garmet you can take it off and stick the wire there. It will come out from a hole near your fuse box.
