Runing power wire
there's a plug in the firewall right behind and down a little from the throttle body, after you poke thru, angle it towards the drivers side and should come out somewhere around the top of the gas pedal, then just run it .
I just drilled a hole and ran the power wire that way. If you do it that way be sure to put a rubber gromet of something there so it doesn't cut through the power wire.
Hey this is gonna sound haggard, but, I took off my left front quarter pannel (6 bolts) behind there is a conduit wire run from you head light and all that stuff, take off your left corner light and run the wire along that conduit, there is a grommet in there about 2" i ran 4 gauge wire through there with no problem. If you have any questions about this send me a message, i just did this so i know how much of a pain it is.
by quarter panel, I'm assuming you mean the FRONT DRIVERS SIDE FENDER...............
The term "quarter panel" is usually used to describe the REAR panels, not the front.
Im sorry i will be sure make sure i have all of my terminology correct before i try to help someone out, yea, take off the back panel when getting to the battery, you anal prick.....
Hey man, I would have said the same thing as him.
Chill.
We like accuracy here, plenty of folks have said "yo, there are mad holes in that firewall yo".
Unkay, that doesn't help.
Some folks have their batteries in their trunk, how do we know you don't?
Chill.
