Removing Speaker Covers
i just wondered how you go about removing the front and rear speaker covers or if its even possible. it didnt seem like they were going to budge just by pullin at em and i didnt want to break anything
Vehicle: 97 Tiburon
you have to take the door panels off for the front speaker grills... they are held in w/ screws from the back of the panel.
and the rears just pry off
Vehicle: 2015 Subaru WRX
to take the front off youll have to take the door panel itself off. Its not hard, there are three or four screws around the outside. Then youll have to take the screw from behind the lever you use to open the door. There are two next where the vents are.
Now you should be able to lift the panel up, so youll have to disconnect the the connecter that goes to the window and mirror controls.
Take the panel off, there are four screws behind the speaker cover. Viola... nothin to it.
