Removing Center Console
Re: Custom Short Shifter.
Hey guys. I was installing my Oz short shifter yesturday and tried to remove the center consol. I unscrewed the 4 screws that were there and removed the car stereo plastic surround. I tried to remove the center consol but it wouldn't budge. Is there something that I forgot to remove or is there a screw someplace. I opened the consol compartment and found no screws or bolts there.
Re: Results from tonight's race :)
Yeah, I think there are 6 screws on it. 2 up front, 2 by the front of the seats, and 2 by the rear of the seats.
Wife has the car so I can't check.
Re: FS: Brand new 340cc BETA II injectors
That's right REDZ.Basically,there are 4 front and 2 rear.Then you have to crank the e-brake up as much as possible.The console should slide right out/off.
Re: Removing Center Console
You know.......
Its NOT absolutely necessary to remove the center console to install a SS.
I installed both my B & M and my RSide with mine still in place.
