remote start
im only asking because i know that the steering column harness is behind the steering column and thats where i found the heater/acc wire but i havent found anything to hint to me of an ignition switch harness where i can connect my starter wire and anti grind wire. its the only wire i need left, and the most important lol
unless its the harness connected directly to the key ignition switch. cause if it is I just may be retarded.
searching the12volt.com:
"| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness |
| STARTER|white |+ |ignition harness |
| IGNITION|green |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|blue *1 |+ |ignition harness |
| POWER LOCK|add actuator *4 | |in driver door |
| POWER UNLOCK|same | | |
| PARKING LIGHTS +|grn/org(L),grn/blk(R| |driver kick panel |
| PARKING LIGHTS -|green | |headlight switch |
| HEADLIGHTS|yellow |- |headlight switch |
| DOOR TRIGGER|green |- |driver kick panel or cluster|
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green/orange |- |driver kick panel or cluster|
| HOOD PIN|yellow/black |- |pin switch |
| TACHOMETER|gray *2 | |ECM under driver dash, pin 8|
| SPEED SENSE|white/black | |data link connector *3 |
| BRAKE WIRE|pink/black |+ |brake pedal switch |
| HORN TRIGGER|blue/orange |- |steering column |
| WIPERS|green (L), brown (H)|- |steering column |
| LF WINDOW UP/DN|blue - green |A |driver window switch |
| RF WINDOW UP/DN|gray - orange |A |driver kick panel |
| LR WINDOW UP/DN|black - green |A |driver kick panel |
| RR WINDOW UP/DN|white - blue |A |driver kick panel |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|blue/black |+ |radio |
| RADIO ILLUMINATE|green/orange |+ |radio |
| POWER ANTENNA|pink |+ |radio |
| LF SPEAKER|red - blue | |radio |
| RF SPEAKER|white - brown | |radio |
| LR SPEAKER|green - orange | |radio |
| RR SPEAKER|orange - blue | |radio |
Notes:
*1 This wire is not required for remote start. *2 Can also use blue or brown at the ignition coils. *3 The data link connector is under the driver side dash. *4 Vehicle with keyless entry use black/orange for lock and yellow for unlock. They are negative trigger and found at the ETACS module to the left of the steering column."
http://www.the12volt.com/installbay/...s.asp~TID~7139
Notes:
