Rd2 Seoulfulracing Rest/dead Petal For Manual Tranny
I need help with the following a while back ago i bought the whole set of rd2 korean petals inlcuding the foot rest for manual tranny for any of you that have done this conversion how that hell did you install the petal. the petal has a hole on the top right corner where does it go how did you install it. I cant freaking figuere it out
thanx
thanx
thanx I red redz DIY. I was having a mental block thinking it was meant to be bolt it right in since the pedal did bolt right in. Sometimes the most simple things can be overlooked
See, a perfect example of why spelling correctly is important. You won't find the DIY if you search for PETAL, but if you search for PEDAL, you will.
LOL
LOL
Why did you ask me this in here, AND in PM?
Keep your questions in the forums, it helps EVERYONE out, instead of in PM's just helping you out.
I just went through my extra screws in the garage and found something shiney, phillips headed, and self tapping that fit the hole.
As for the part you need to cut off, yes, it's the little secondary mounting tab that looks like a D shape with a hole in it.
