Radio Install Woes...
Old Dec 7, 2004 | 10:15 PM
customchevy1971's Avatar
Default Re: Hard to Starter
Big problem. Its 11:14 and my dash is apart due to installing my new stereo. Problem is, according to my checklight and the fact that the deck doesn't power on, i'm getting no power to the wires for the head unit. I've checked the fuses and racked my brain, and I'm truly stumped, makes no sense to me. Yes, my lights properly grounded. If anyone can help, i would love it.
Old Dec 7, 2004 | 10:19 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Default Radio Install Woes...
did you disconnect the ground wire from the battery? before installing ur HU...if so make sure you placed it back on the terimnal good.
without any more information , your the only one that knows what you did :roll:
Old Dec 7, 2004 | 10:25 PM
Casper's Avatar
Default Re: RDTiburon Decals!
Any power from the Yellow wire? (on all the time)
What about the Red one? (key on accessory)
Old Dec 7, 2004 | 10:36 PM
MAXXTIB's Avatar
Default Re: December 7th 1941
How did you wire it in, did you cut up the factory harness or did you buy a harness adapter. I have come across quite a few of those harness adapers that where wired wrong, and if you cut up the factory harness maybe you just got it wrong, I would probe all the wires with the test light to see if there is power going to any of them.
Old Dec 7, 2004 | 10:48 PM
tanc's Avatar
1 Illumination (-) Green/Black
2 Rear Left Speaker (-) Black/Red
3 Front Right Speaker (-) Red/Black
4 Front Left Speaker (-) Red/Black
5 Rear Left Speaker (-) Black/Red
6 Power Antenna ???
7 Illumination (+) Grey/White
8 Rear Right Speaker (+) Black/Light Blue
9 Front Right Speaker (+) Red/Brown
10 Acc (+) Light Blue/White
11 Battery (+) Red/Yellow
12 Front Left Speaker (+) Black/Red
13 Rear Left Speaker (+) Brown/Red
14 Ground Black
Old Dec 7, 2004 | 11:24 PM
Ok, figured out previous problem, but I don't understand why I don't have the same colors as posted for the speaker wires. I only have 2 black wires, 1 is ground. ???
Old Dec 7, 2004 | 11:34 PM
tanc's Avatar
Default Re: Radio Install Woes...
the thickest black wire is your ground.
Old Dec 8, 2004 | 10:11 AM
MADTIB's Avatar
Default Re: Sharkracing
Get a multi meter, then you can figure it out on your own.
