Hyundai Aftermarket
-   Interior, Sound, Security (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/)
-   -   Pics Of Sub Install?!? (https://www.hyundaiaftermarket.org/forum/interior-sound-security-14/pics-sub-install-47989/)
bassboy3313 May 8, 2008 07:17 PM
Hey. Does anyone have pics of where they ran their subwoofer power cable through their firewall? I just want to get an idea of where to drill the hole. Thanks.
Caj Darkmoon May 8, 2008 07:25 PM
Assuming that RD1's are the same, and I believe they are, do not run it through the firewall. If you remove the drivers side mud guard and front fender you will see a plastic grommet that gives access from inside the fender to the drivers side footwell. You can run the power cable from the batter, into the fender area, and through that grommet, and then back under the carpet.
Bandity2k00 May 8, 2008 08:28 PM
The big amp power wire wont fit threw that garment with the hood latch cable threw there too. Just drill a whole.
Caj Darkmoon May 8, 2008 08:36 PM
radu_rd2 May 8, 2008 08:59 PM
There was nothing going through that grommet in my car. I think it is only used if you have a sunroof. My 4 AWG wire fit perfectly through it. You don't need to take off the fender BTW, just the inner lining.
Caj Darkmoon May 8, 2008 09:44 PM
Nope, I had wires and no sunroof.
tib _500 May 8, 2008 09:54 PM
i think RD2s only use those holes for sunroof leakage run-off. there is a hole by all four cabin corners.
Caj Darkmoon May 8, 2008 11:28 PM
And I'm telling you that you're wrong...
aknapp11 May 9, 2008 01:47 AM
i used 4 gauge wire but i ran it around the back of the engine bay to the passenger side there is the same grommet there too.
Bandity2k00 May 9, 2008 07:13 AM
I just replaced my hood latch cable 2 weeks ago, It goes threw the grommet on a RD1, Just drill a hole in your firewall on the drivers side, where you think you can hit the hole, and then push it, then pop off your running boards and you run it in there with the other wires back to your subs then clip the plastic boards back on. Ill try and get you some pictures when I get home.
