Oil Pressure Guage Help
Old Nov 11, 2005 | 03:32 PM
OneBadtib97's Avatar
I just bought to guages to put in my pillar pod, i got the water temperature gauge hooked up fine, but what do i need to do to hook up the oil pressure gauge, if anybody could help that would be great thanks.
Josh
Old Nov 11, 2005 | 06:03 PM
xtremeskier's Avatar
It's pretty simple. Just hook up your oil pressure sender into your engine block. There should be a plug in the drivers side on the engine block which can be removed by a allan key. Carefull cause oil will start to come out (not a lot). Then screw in the oil pressure sender, tighten it, and run a wire to your gauge through a hole in your firewall. Don't over tighten it otherwise you will strip the threads.
Here's a picture of mine.
Old Nov 11, 2005 | 06:10 PM
i didn't get that rounded piece there like you got all i have is a small white hose like a vacume line size hose that has to be hooked up somewhere
Old Nov 11, 2005 | 06:13 PM
Really. Hmm. The only other thing i can think of then would be to get a T-Connecter and hook it up to where the oil warning light sender is located. Not really sure how to do that though, sorry.
Old Nov 11, 2005 | 06:32 PM
hmmm thanks anyways man, if theres anybody that can help please do it would be greatley appreciated thanks
Josh
Old Nov 11, 2005 | 08:18 PM
you got a mechanical oil pressure gauge. you dont want that. you will have to run that white tubing, full of hot oil, into your cabin.
Old Nov 14, 2005 | 02:11 AM
BlackTibby00's Avatar
^^^^Is that a bad thing? I've got the same type. You have to run an 1/8" copper tube from the gauge to the engine. BUT, where do you hook the tube up to?. I just bought it and don't really want to sell it.
Old Nov 14, 2005 | 02:22 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
bad thing is - if there will be a leak - oil will get in the cabin
Old Nov 14, 2005 | 03:48 AM
^^^But what are the actual chances of that happening. Probably slim to none.
Old Nov 14, 2005 | 03:51 AM
Dmitry's Avatar
secure that tube so it wouldn't rub anywhere, especially in the firewall. Also don't forget that engine is moving a bit, shaking... so tube should handle.
