New Trunk Mod
Well guys ben a while since i have ben on here got a bit done since last post
i know its not a pro instal and there is "wood" showing witch is why im looking for a new one of these to put in there till perfected but anyways let me know what you guys think
Looks pretty nice!! Where'd you get it, how'd you mount it and what's it made from (acrylic I assume)? You could probably just roll the carpet over to hide the wood edges, rather than trying to jig up something different.
Thanks Man means alot that people like it even thow its kinda crappy laugh.gif
Its 8x8 plexi a member of my other forum made it for me and its hot glued on the corners this was just pretty much a test run at it looking to be a new one from someone on here to try it again with pulling the carpet over the edges
quick way to fix that up. use masking tape and tape over the entire surface top and bottom and then use a exacto knife to cut around the edging and then spray the edges black and then dry, rip off tape and pop back in there. it will make the edges nice and clean and black!! fing02.gif
