New Gauge Bezels
Old Mar 1, 2007 | 05:07 PM
Spiffywerks's Avatar
The AOS gauages shift around. They can be moved around to make fit perfect into the hash marks.
I noticed when I installed my AOS gauges, i had to put little dabs of glue on the backside to make sure it didn't shift and move out of place when I set everything in. When I first put them in, they did the same thing on the higher MPH until I moved it around a little. Nudging fixes that issue. I'm sure the bezels are fine.
Old Mar 1, 2007 | 05:12 PM
Caj Darkmoon's Avatar
Personally now that I've seen them in-car I'm even more sure that I like the square cutouts of the stock bezel more.
Old Mar 1, 2007 | 05:15 PM
QUOTE (Spiffywerks @ Mar 1 2007, 07:07 PM)
I know what you're talking about, but If installed properly, you cannot nudge the gauges nor the rings. They have fixed points to which they attach on the plastic behind the gauges.
btw.. the "comb teeth", and the circling the indicators were my suggestions to REDZMAN smile.gif
Socks: yes, i'd like them back, seeing as how they don't look like they will work with a set of AOS.
Old Mar 1, 2007 | 05:16 PM
I know they have fixed points where they are attached, but you can still nudge them around a bit. When I first installed my guages they looked like that with the stock bezels. I had to move them around to get them to sit perfectly the way I wanted them too. I also left the stock guage behind the AOS gauge. The holes of the AOS and the stock guage don't line up perfectly. In fact I had to make an additional hole and trim a little off the edging to get it to sit perfectly.
Old Mar 1, 2007 | 05:19 PM
btw socks... is that your bank account information in that pic?
Old Mar 1, 2007 | 05:28 PM
lol, yeah its a cancelled credit card lol.. its been cancelled for about a year, but i just cleaned out my desk to throw it out.. loll lmao.gif lmao.gif
and itll work with the AOS gauges, they just need to be installed the right way, lol.
daafisch's Avatar
SOCKS the speedometer is is off if you look at the pics with the lights off. Between 115 and 140 is it a little off. As for those stock black pieces the speedometer has them in there
In this process I lost 2 of them so the rpm and the other ring are held on half by glue and half by those black pieces. I might have to see if I can move them to get them to fit properly because they look perfect on the stock faces...
Otherwise im happy
Old Mar 1, 2007 | 05:33 PM
well the AOS should look EXACTLY right, because the way the lines points are the points are on the centerline, so if the bezels looked right on the stock gauges, it would look right on the AOS, ebay, or any other gauge..
i know its off in your pics, but you need to adjust the location of the face it looks to fit the bezel like spiffy said.
if you jus tlook at the speedo face, you can tell the face needs to be moved up a lil and rotated a bit counter clockwise..
Old Mar 1, 2007 | 05:34 PM
Guys, if you lose pins installing these, use some SMALL fine thread screws, works great.
Mine will be going in this weekend on my AOS.
Old Mar 1, 2007 | 05:57 PM
^^ looking forward to seeing that REDZ.
If the blinker indicators become a problem just chop those fuxors out of there. You don't need them on the gauges for the gauges to display arrows with the new rings.
