Need amp config help
Old Apr 5, 2010 | 11:48 AM
hornet's Avatar
Vehicle: 2001 Accent
Default Need amp config help
2x of these:
http://www.kenwoodusa.com/Car_Entertainmen...ofers/KFC-W3012
With this amp:
http://www.kenwoodusa.com/Car_Entertainmen...plifiers/X1200M
Old Apr 5, 2010 | 11:53 AM
I assume those subs are DVC. Wire both of them in parallel to drop the amp to 2 ohms...so you get 600 watts RMS to both subs. Leave the Bass Boost at 0, adjust the gain, adjust the frequency to around 60-80hz, and BAM! Your almost set...just adjust where neccessary.
Also, adjust the infrasonic filter to 40hz since your subs lowest frequency is 39hz...you wont hear anything below that anyway.
Old Apr 5, 2010 | 04:16 PM
They are not DVC unless he gets the KFC-W3012DVC instead of the KFC-W3012.
If you run the + from the amp to both + on the subs and the - on the amp to both - on the subs, your amp will see a 2 ohm load and feed each 600w RMS.
As for tuning, go with what V said. Lol.
Old Apr 6, 2010 | 12:16 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
