Re: RDTiburon Decals!
that has to be seriously heavy? eh? Good job though!
Re: My new box :) *with pics*
actually, its not to bad i tried to make it as light as possible so it only about 40-50 pounds
Re: ok.. run this by me one last time
Looking pretty good.I'm glad to see that you used MDF.Alot of times beginning box builders use wood that is not "accoustically dead".Make sure that you caulk the internal seams and use alot of poly-fill.Also, make sure that your subs don't slosh around inside the mounting holes.In other words,be sure that the mounting holes are cut out just right.Otherwise you'll need to seal them up real well.
Email Announcements
Threw me off with the cut holes being a different size than the circles you drawed. Were you planning on using bigger subs and then stepped down or what? The box itself looks good tho!
Re: OZ-BBTB
uh yeah, i dunno what happened with those holes. using math....they shouldve been right....but all my other math was right so its all good. and yes we got polyfill in it and are buying some more tomorrow. and there is a LOT of chalk on all the core box seams. there are new air leaks ANYWHERE. we went to extremes to make sure of that.....laugh.gif
and thanks for the comments and all the help planning this. |
Re: Any Hunters here? Caution: Graphic image of dead animal
<div class='quotetop'>QUOTE </div><div class='quotemain'>........and there is a LOT of chalk on all the core box seams.</div>
Chalk??? I never heard of using chalk to seal up a box.......hmmmm. 8O <div class='quotetop'>QUOTE </div><div class='quotemain'>......there are new air leaks.....</div> Well, you better seal'em up. laugh.gif |
that's a good sized box but you managed to keep your back seat.
Re: Clutch problem
How did or is the box mounted? And I guess from the looks of it that the box is just sitting on the upper floor in the trunk over the spare?
Re: National POW/MIA internet Blackout day ATTN:MODERATORS
er, um....couple typo in my last post, u know wat i meant! i meant no air leaks anD caulk.
<div class='quotetop'>QUOTE </div><div class='quotemain'>How did or is the box mounted? And I guess from the looks of it that the box is just sitting on the upper floor in the trunk over the spare?</div>It is just sitting ont he upper floor . i will do a MUCH better job making it look good when we get the carpet. |
