Mini triple gauge set
Old Nov 17, 2009 | 01:12 PM
accent03's Avatar
Vehicle: 2003/Hyundai/Accent
Default Mini triple gauge set
Purchased from harbor freight and consists of ammeter, mechanical oil gauge, and water temperature gauge.
Need help with placement being there is no place to mount it.
I may just customize some stuff and end up cutting to it slides right in custom. but i don't know if that's the best idea.
heres what im working with..
Old Nov 17, 2009 | 07:17 PM
That's going to be a rough install. I say in the glove box.
Old Nov 17, 2009 | 09:13 PM
accent03's Avatar
QUOTE (187sks @ Nov 17 2009, 09:17 PM)
inside so it just chills in there?
Old Nov 17, 2009 | 09:22 PM
easy as cake. just make some aluminum L brackets, drill some holes using a hole saw matched to the size (shouldn't be hard given the right angle), screw it in, fiberglass it over and boom done.
the hardest part should be matching the paint color of the dash.
Old Nov 18, 2009 | 01:36 AM
QUOTE (accent03 @ Nov 17 2009, 08:13 PM)
QUOTE (187sks @ Nov 17 2009, 06:17 PM)
You can use a rod to lock it open when you want to be able to see the gauges and still be able to close it, or have it open all the time.
