MADTIB, Advice needed
Old Aug 30, 2004 | 09:49 PM
AllBlackTibby's Avatar
Default Re: Fosgate Amp
I was thinking of changing my setup around, tell me what your opinion is.
Currently I run a Sony CDX-MP70 HU, Audiobahn A4002T 2 channel amp (400 x 1 mono) and a Infinity 1030W 10" 4 ohm 250 watt RMS sub.
I have Sony 6.75" in the 2 ways front, Sony 6 x 9 3 ways in the back, all currently powered from the HU.
Do you think it would be good to leave it as is, or change the Audiobahn out for a Alpine MRV-100M amp that I got to power the sub and use the Audiobahn in 4 ohm stereo mode (2 x 100) to power a nice set of components up front and the HU to power some nicer 6 x 9's in the back?
My only concern is the Alpine amp.....it doesn't really put out enough RMS power to the sub. Infinity recommends 250 watt RMS. Maybe I should get a different sub......something that closer matches the RMS power of the amp?
Thanks in advance.
Old Aug 30, 2004 | 11:17 PM
MADTIB's Avatar
Default Re: Alz99mobile
......or change the Audiobahn out for a Alpine MRV-100M amp that I got to power the sub and use the Audiobahn in 4 ohm stereo mode (2 x 100) to power a nice set of components up front and the HU to power some nicer 6 x 9's in the back?
I'd leave the rear's on the rear output of the hu.Certainly put some good 2 way components up front and power them.
Do you like the Infinity sub that much? If you do, then maybe you should sell off the Alpine and get another amp like you have now.I personally think it's best to use the same brands for amps.
If you really don't care that much about the Infinity, then sell that and go with a sub that'll be closer to the Alpine's output, like you said.
