lights
Old Apr 5, 2004 | 01:25 PM
peter_2150's Avatar
Well my clock and and lights in the inside stop working does any1 know what the problem could be (btw i did check the fuses and them seemed to be ok) o and i did replace my cig lighter with a switch.
edit-(NM it was my sunroof fues)
Old Apr 5, 2004 | 04:39 PM
sdtiburon's Avatar
I had the same problem once before too. It is definately a fuse. Open up your fuse box by your feat and check them again. I don't remember exactly which one but one of them should be blown.
If all the fuses look good in the fuse box, then I really don't have a clue.
Old Apr 5, 2004 | 05:04 PM
MADTIB's Avatar
Default several topics
What do you have on the other end of this switch? In other words,what is the switch supplying power to?
Old Apr 5, 2004 | 06:36 PM
Default Newbie with a couple of quick questions
clock and cigarette lighter are on the same fuse...
Old Apr 5, 2004 | 06:40 PM
QUOTE (Peter_2150@msn.com)
Fantastic mang.
