LEDS for interior lights?
Old Oct 31, 2004 | 11:44 PM
zoned019's Avatar
Vehicle: 97 Tib
Default rd1-->rd2 FRONT END conversion
what size leds should i buy, tomorrow i plan on doing some mods (like the window switch one), maybe attempting to make my own ac/recirc switches in blue, etc. just wondering what is a good size led and do you think i can get them at radio shack?
otherwise, tibby01 don't you have a bunch for sale really cheap? give me like a dozen.
Old Nov 1, 2004 | 04:37 AM
javageek's Avatar
Default Re: *Exhaust Listings* *BIG BORLA UPDATE*
You can get them at RS, but it will be alot more than online. Go to www.superbrightleds.com. 5mm LEDs should be the ones you need.
Old Nov 1, 2004 | 07:13 AM
tibwrcsbj's Avatar
Default Re: Internal Vs External
Zoned, most of your questions are answered in the DIY's.
Old Nov 2, 2004 | 09:15 AM
Default Re: FS: Korean spec license plate from decalgirl.com
ok, aside from the heater/blower assembly, you will need 12 led. 8 will need resistors.
the resistors are tricky fitting in there though. you can try cutting the power wire behind the switch and splicing a resistor inline with it, or you can try fitting the resistor somewhere on the switch.
