Interior Door Panel Removal
http://www.hmaservice.com/webtech/default.asp
Go there, put in your year and model...go to the shop tab up top...click on "Body (Interior & Exterior)"...Click on "Hood, Doors, & Trunk Lid"....Click on "Front Door"...Click on "Removal and Installation"...then scroll and read.
7 Screws to remove.
1 - behind the pull lever. (remove the plastic insert after removing the screw)
2 - Inside the Handle (Remove the rubber inserts to get at them.)
2 - at the front of the door, next to the hindge. One is near the air vent, one near the bottom. They can be seen pretty easily.
2 - at the back of the door when you open the door you can see them.
Make sure you roll down the window to make it easier to remove the panel.
Pop off the little plastic plate at the top of the door that covers your Mirror mount.
Start from the the bottom of the door panel and start pulling, out AND up. Be mindful that you have your Door light and your window control unit still connected to the panel. The door light twists out easily, The Switch, you'll have to reach under the switch and disconnect it. It has a tab that you press down and then you pull it out. (best I can describe without pictures.)
Umm.. I think that's it unless someone else wants to add something.
please do not post requests for DIYs int the DIY forum. it is for complete DIY write ups only. requests can be put up in the other forums, as that is pretty much their purpose. smile.gif
since you are still pretty new, i will do a search for you.
http://www.rdtiburon.com/index.php?showtop...1&st=&p=&#entry
