installing HU
Old Nov 28, 2003 | 11:48 AM
Tank's Avatar
How do i remove the frame around the stereo area to install a head unit?
Old Nov 28, 2003 | 12:08 PM
canadianshark74's Avatar
Default installing HU
First, pull up on the part that surrounds the shifter, then the pull straight out to get the part that is around the HU out. they are all held in with clips.
Old Nov 28, 2003 | 02:12 PM
You can buy a wiring harness and dash kit (to fit single DIN if you came with double DIN) from almost any store that has car audio. Should run about $15-20 total.
As canadianshark said, pull up on the shifter surround plastic piece, then pull the headunit surround directly towards the shifter. If you have an automatic, you may have to drop the auto down into 2nd to get it out. You also have to open/close the ash tray to get it in/out. No big deal really
Old Nov 28, 2003 | 02:14 PM
Tank's Avatar
the screws around the shifter didnt really want to come out, i tried to take one out and it got sort of stripped. Do i take them out or do i just pop the part around the shifter off? (its manual)
Old Nov 28, 2003 | 02:24 PM
those screws around the shifter are just for show, the whole piece is plastic.
I think we all have tried to undo at least one of those screws when we wanted to get that piece out.
Old Nov 28, 2003 | 02:31 PM
Tank's Avatar
Old Nov 28, 2003 | 03:28 PM
Solo-Baric's Avatar
QUOTE (canadianshark74)
speak for your self! i didn't!
Old Nov 28, 2003 | 03:36 PM
When I had to get the shifter surround off, I figured that they were plastic, but I couldn't resist trying to see if they were actual screws. I quickly figured out that it was plastic, and yes I felt dumb.
Old Nov 28, 2003 | 05:40 PM
best way to pull up the shifter surround.. get your fingers under the edge where it meets the boot and give it a good jerk upwards.
Old Nov 28, 2003 | 10:10 PM
careful not to break it though. I broke a small corner off of mine because the damn clip wouldn't un-clip. It's still very stubborn when coming out. Just pull upward and it'll come. No screws necessary (except the ones that hold in the HU)
