Installed AOS guages
Old Apr 21, 2003 | 10:42 AM
Max_Kool's Avatar
Default Installed AOS guages
Here's a pic of my 2000 Tib AOS reverse indiglo guages if anybody wanted to see...(Sorry about the size!!!)
Old Apr 21, 2003 | 11:01 AM
AllBlackTibby's Avatar
Hopefully a mod will edit the size for you.
Three questions; how uch, where from, how easy/hard to install?
They look awesome BTW!
Old Apr 21, 2003 | 11:09 AM
long's Avatar
i believe speedstate.com sells them.
Old Apr 21, 2003 | 11:19 AM
Max_Kool's Avatar
yeah....speedstate.com. Took me less than 30 minutes. I had SR guages in there before so I knew how to do it. It's relatively easy though.
$80
[ April 21, 2003, 06:19 PM: Message edited by: Max_Kool ]
Old Apr 21, 2003 | 05:51 PM
How do you run the wires?
Old Apr 21, 2003 | 09:28 PM
Max_Kool's Avatar
I drilled a hole in the back of the guage cluster and just dropped them straight down. I put the little switch and knob thing kinda low on the drivers side of the console. I'll try to get a pic of it if you need it.
Old Apr 21, 2003 | 10:37 PM
Ehh, that's ok. Just wondering how you got yours hooked up.
I've got a Racerboy Shift Knob, all my internal lights are going to go to one button, externals to another, amp to the third, and save the 4th for NAAAAWWWWWWZZZZZ!
Uhm...
LOL
Old Apr 22, 2003 | 01:00 AM
Switch and knob??
Do you have to manually turn them on or something?
Also, did you have to take your needles off to install these? Did you have any problems with fitment? I know in the past others have said that indiglo gauges had problems with making the needles stick which is something I don't care to deal with.
Where did you end up running the wires too?
Sorry so many questions!
Old Apr 22, 2003 | 02:13 AM
Max_Kool's Avatar
Theres a switch/knob combo thing. The switch is used to change the colour from blue to green. The knob adjusts the brightness. They get pretty bright. They fit on perfect...except I had to use a needle to make a hole on the bottom right hand corner of the far left guage. Nothing big. The wires I ran through a hole I drilled in the back of the guage cluster....I have a spare gauge cluster I can drill and take a pic of if you need it....then ran the wires down behind the dash and then down to the bottom of the center console. I just put the knob thing there because I lost motivation by then (short attention span). This weekend I'm sure I'll put it somewhere else.
And yeah....I had to take the needles off.
Old Apr 22, 2003 | 04:35 AM
Max,
If you don't mind, pics would help. PIcs of the cluster and where you mounted the button/switch would be helpful.
Thanks!!
