I need a Gauge install cheat sheet
Old Sep 10, 2001 | 02:29 PM
Fast.Type-S's Avatar
Default I need a Gauge install cheat sheet
Who has a good (like speedstate or alike) for install indaglo gauges? What about an install page for the SR gauges? Ohhhhhhhhh..RANDOM... wink.gif
Old Sep 10, 2001 | 02:32 PM
http://www.teamsr.org/installguide/gauge_i...tall/how_to.htm
Just DO NOT hook the Indiglo's up to the dimmer switch. Hook them up to some other 12V power source that comes on when the lights go on. The Parking lights would be a good option. The varing voltage of the dimmer swith can burn out the indiglo's.
Old Sep 10, 2001 | 02:50 PM
K thanks for the hint random. I did power it up to my battery for a few seconds..so I could test it b4 the long install. What is the guesstamated time for install? Also should I consider finishing my interior (dash) painting at the same time? Color's look SWEET!!!!
And on the mebers page? i have a few pic's ready...
Old Sep 10, 2001 | 02:58 PM
Choopi's Avatar
I did mine, I got the indiglo gauges from E-Bay, and it took my about 2 hours to do the whole thing.. I wired my 12V to the acc. of the radio. Followed by an inline fuse. Not that hard of an install, just hard as hell finding all those little damn screws.. Random's page helped very much, too bad I didn't see it until after I got everything apart.. wink.gif
Old Sep 10, 2001 | 04:00 PM
Those seem like they should help. Thanks!
Old Sep 11, 2001 | 01:49 PM
Originally posted by Tunez:
3. To hook your wires into the park lights, which is the smart thing to do so they don't stay on all the time. Look under the dash a couple of inches to the left of the steering column and look for a green wire with a white stripe on it. I'm thinking that it was in a (white?) plug with like 6-8 wires. When you find a green/white wire, make sure to test it first. For the ground wire, just use a screw and put it into the metal behind where the plastic fuse cover trim piece is.
Can yopu please check to see which wire you did us? Currently is ran into my fog light fuse...so i need on to be ran closer..and not that long of a wire..hehhe
thank man
Old Sep 11, 2001 | 10:51 PM
QuikTib's Avatar
There are little black "push in pins" holding these pieces in. Be careful pulling those out cause when they break free they will fly off if you are not careful.
Are you refering to the rest pins?
if so I had this happen to me when pulling off the stock gauges, that little pin went flying never to be seen again. Well I came up with this little fix that might help anyone who made the same mistake. All you do is go to your local department store and pick up a hair brush(not comb) with black bristles and those little plastic balls on the ends, then cut one off and trim it to fit thru the hole in the gauge cluster the rest pin came out of (the ball on the end should keep it from going all the way thru), when you have the correct length established super glue it in place, and viola you just fixed yourself a rest pin.
On a side note if you don't lose both pins I would recomend puting the one you have in the speedo place and put the make shift pin in the RPM guage, its less noticable.
Hope that helps anyone.
Old Sep 12, 2001 | 01:12 AM
QuikTib's Avatar
OK, but I'm sure I'm not the only one who has lost a rest pin like this, so this is a quick and easy way to replace the rest pins if lost.
