I hope this keeps the road noise down!!!
Old Jun 25, 2008 | 09:13 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Default I hope this keeps the road noise down!!!
This is what i have been working on while im waiting on my beta parts. Do you think this will keep the road noise???
Old Jun 26, 2008 | 11:42 AM
J0eFr0's Avatar
Vehicle: 2000 Hyundai Accident
just picture that Toyota commercial where they guy is in the car with a ferocious sleeping badgers and they shoot off a cannon and it doesn't wake the badger up up...
http://youtube.com/watch?v=TOuyGX56CWY
Old Jun 26, 2008 | 01:36 PM
That should work pretty well.
Old Jul 8, 2008 | 06:52 AM
Ryanator's Avatar
Vehicle: 2003 Hyundai Accent 22PSI Boost
In my old Accent, I added 4.5Kg of Polyguard... A spray on polyurethane coating with rubber flakes about 4mm thick just to my hatch. Thing is so heavy to get up and down but I gained 4DB from doing it. Another good stuff to use is DYNAPLATE or DYNAMAT.
Cheers Ryan
Old Jul 8, 2008 | 10:48 AM
Just kidding...you should definitely hear a difference with all that. Are you doing it just for road noise, or for better stereo sound?
Old Jul 9, 2008 | 03:53 PM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
That looks expensive. I dont have the money to pull stuff like this.
Old Jul 10, 2008 | 03:26 AM
QUOTE(Whiplash @ Jul 9 2008, 04:53 PM)
It only cost me around 80 bucks for the stuff. I thought it would be more but it wasnt.
I got it from here <--------
Old Oct 2, 2008 | 02:12 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
i have edead and upholstery grade foam in my car..
it's very quiet when i'm in the car..i can't hear wind or other nearby sounds..
it definitely helps the bass and roada noise, add some on the hood and it'll be quiet as a lexus..unless you have a intake
it also helps dampen the sounds of road debree being kicked up on your fenderwells, like pebble's and sticks.
Old Oct 2, 2008 | 02:20 PM
Where did you install the foam at?
Old Oct 2, 2008 | 02:44 PM
Tak82's Avatar
the quarter panel cavities, i took off the plastic panel and stuffed it like crazy, helped the NVH alot..
