How To Wire Afr Gauge?
Old May 18, 2006 | 06:18 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I'm going to wire AFR gauge.
What are the best places to get +12V (hot at on), +12 (for backlight) and ground?
Do I need to use a fuse for +12V?
Thanx!
Old May 18, 2006 | 08:00 AM
homey14h's Avatar
Im not goin to lie... I have NO idea what that means lol
But can you do a DIY on this? this would be a great addition if people post a DIY on wiring up aftermarket gauges.
Old May 18, 2006 | 09:28 AM
Jay-M's Avatar
Vehicle: 01 Tiburon
this where you can tap from:
switched +12v:
- ecu pin # 58. since your are tapping your o2 sensor from the ecu harness, might as well take power it from that area
- find an empty spot on in you fuse box and tap it from there
note: yes, it's always a good idea to fuse the power... but not really necessary... most of the sources under the dash is already fused
backlight (and maybe gound):
ground:
- ecu pin # 55
- or find any bolts/screws that is connected right to the metal body of the car and get it from there
Old May 18, 2006 | 09:39 AM
i wouldnt even bother with getting the switched from the ecu harness. there are tons of other switched sources that are much easier to access. the switched radio wire would even work. if you are putting the gauge on the pillar and have a sunroof, there is a hot wire running through there as well.
Old May 21, 2006 | 11:21 AM
Dmitry's Avatar
thanx guys!
I just don't want to take out dash and doing some pita work, lol
