How To?
Old May 14, 2006 | 10:46 AM
gsasha1's Avatar
Vehicle: tiburon 1998
Hallo there!
I have a relatively old kenwood panel (model 2020 ? which can control a changer, so I believe...)
and a relatively new mp3 player.
The only outlets on the mp are mic and line-out.
The only inlet left on the back of the panel is a circle with many dots in it (coaxial ? )
how do I get to hear all my nice downloaded songs through the car audio?
is this what I'm looking for? :
http://cgi.ebay.com/ebaymotors/60-70-s-Por...1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/Alpine-Ai-N...1QQcmdZViewItem
Thanks,
Sasha.
Old May 14, 2006 | 11:11 AM
i dont think those will work man. that plug might fit in the changer plug on your headunit, but there is a chance the pins will be configured differently inside the headunit. unless you are able to find a specific kenwood adapter, i wouldnt chance it.
if your headunit has an aux input, you can use that. guessing it does not though, a lot of older ones dont.
Old May 14, 2006 | 11:21 AM
SilentSecret's Avatar
Vehicle: 1997 Hyundai Tiburon
QUOTE (gsasha1 @ May 14 2006, 09:46 AM)
Hallo there!
your just gonna have to burn it to cd like all the common folk do.
or buy a new deck or get a better mp3 player that will broadcast it through your fm radio.
Old May 14, 2006 | 01:22 PM
gsasha1's Avatar
^^ not funny.. Next thing you're going to suggest is buying a GK instead?!
Common guys..... Get creative!!
Nope, no RCA...
Old May 14, 2006 | 01:31 PM
you could get a fm modulator. its this thing you put inline with the antenna, and when you tune your radio to a certain(unused) frequency, it will act as a line in.
Old May 14, 2006 | 01:34 PM
zoned019's Avatar
Vehicle: 97 Tib
fm transmitter = shitty quality.
i don't know what you should do, burn it to a cd is probably the only option you've got mang
Old May 14, 2006 | 01:53 PM
sspangle's Avatar
I think you were on the right track. This should be what you need:
http://www.crutchfield.com/S-1SdggabsZZh/c...aux&i=113CAC1AX
It'll plug up where a cd changer would, and you should run it from the line out and adjust the signal input on the receiver. And FYI, most companies offer something similar; you just usually can't use one with XM or a changer, because you only have one port.
Old May 14, 2006 | 04:00 PM
gsasha1's Avatar
Thanks a lot! placed a bid on ebay...
Old May 15, 2006 | 04:11 PM
^^ does it have a tape player?? You can always use one of those tape adapters.
QUOTE (zoned019 @ May 14 2006, 01:34 PM)
not anymore. the new ones are pretty badass.
Old May 15, 2006 | 10:29 PM
gsasha1's Avatar
No, I have no tape, but it looks too gheto anyway, with a cassete sticking out, and the wire can be seen...
