Head Unit Help
Old May 17, 2005 | 03:12 PM
tanc's Avatar
Vehicle: 1997 Tiburon
The postive wire from the HU touched the top of the HU which caused a spark.
The + wire was not insulated because I was in the process of adding some LEDS and I needed the power wire.
Now my HU doesn't work. I can't take the CD out, and the face won't turn on.
The 10amp fuse for the radio near the clutch pedal area burnt. I replaced that and still doesn't work. I checked the fuse on the back of the HU and it's good.
Now I'm thinking I fried my HU. It's a sony XF7700
Is it possible to send it out to Sony for them to fix it? I've never sent anything back to a manufacture. I bought the HU on ebay.
Any input or advice would be greatly appreciated.
Old May 17, 2005 | 04:07 PM
97tibby's Avatar
Vehicle: 1991 Olds Cutlass
try checking every fuse... just to make sure it did not mess with any other ones..... i had this happen and it was a different fuse then i had no problems.
Old May 17, 2005 | 04:52 PM
tanc's Avatar
I checked ALL fuses. Every fuse looks ok now.
Old May 17, 2005 | 04:53 PM
you might have fried it
most of the time its cheaper to buy a new one but do a search for sony i bet you will find there repair center
Old May 17, 2005 | 05:52 PM
positive wire from the headunit? wtf you talking about? is it a speaker wire, remote turn on, or one of the power wires running to the headunit? what color is it?
Old May 17, 2005 | 06:02 PM
tanc's Avatar
The 12v constant wire touched the top pannel of the HU while it was connected to the HU. I took the insulator off the wire because I was going to add another wire to that connection.
Old May 17, 2005 | 06:06 PM
well, check that wire with a multimeter to determine if the radio is even getting that 12v constant power. if not, you know there is a problem somewhere else.
check that same fuse again, might still have that wire touching something, continually burning fuses.
Old May 17, 2005 | 07:47 PM
tanc's Avatar
I am getting 12v. I already checked.
Fuses have been checked and double checked. It's definetly the HU.
