Guages
Old Sep 24, 2005 | 07:12 AM
Regit's Avatar
Vehicle: 2000 tib
Hi .... I dont have any instructions with these indiglo guages (2000 tib) ...I'm not sure,but I think I should be cutting the circled areas to make the trim rings fit right..Right??? where the wires meet the guage,the trim rings hit it. I've seen some pics of people leaving the rings off..? which is better? also ,does any one have a pic of the headlight wire I should tap into?( first time taking dash apart..PITA,) ha ha thanks!
Old Sep 24, 2005 | 07:43 AM
phorq's Avatar
I have (what look to be) the same indiglo gauges, but I don't remember trimming that piece at all. In fact, I painted that piece, and I'm quite positive I didn't cut it. Sadly, I don't remember what I DID do because it's been so long since I installed them. Sorry for only half and answer! Hopefully someone else will have the other half! As for the wire to tap into, it's one of the wires that comes out of the dimmer switch... but uh, I don't remember which one... (another half answer... sad.gif )
Old Sep 24, 2005 | 09:02 AM
firebug21's Avatar
I think what I did was left those rings on there, but I had to cut a little channel so that the wires will through the gauge and the ring. So that the ring will fit flush against the gauge. I used that circled area to hold the gauge in place.
Old Sep 24, 2005 | 09:12 AM
I posted up DIY instructions for installation of EL gauges.
Old Sep 24, 2005 | 09:16 AM
at the dimmer switch, you want to tap into green/white for power, and black for ground.
as for the fitment, you can notch out the rings, or just notch out the clear plastic peice& stock gauge beneath it.
Old Sep 24, 2005 | 09:35 AM
Regit's Avatar
Vehicle: 2000 tib
Thanks a WHOLE lot! is it ok to put a switch with a 10 amp fuse inline to turn the power off when I want? I've also read you have to disconnect the old lights cause they draw power fr the other lights? hope this is not true..(wires are red & red/black stripe)
Old Sep 24, 2005 | 09:45 AM
you could definately put a swith in to turn them off, but why would you? hook them up to the wires i said, and they will come on and go off with illuminations. it would just be extra work.
you dont have to take out the old lights. the el gauges draw hardly any power at all, and shouldnt pop any fuses.
Old Sep 24, 2005 | 11:21 AM
Regit's Avatar
Vehicle: 2000 tib
Thanks.....will a few littl pieces of sticky tape behind the guages(to keep needlesfree) show through as dark squares??
Old Sep 24, 2005 | 12:10 PM
no. in fact, you should put some back there. make sure its the THIN double sided tape. the gauges are EL gauges. any light they put off is becuase of electricity flowing through the EL liquid in them. they need no backlight at all.
Old Sep 27, 2005 | 08:40 PM
Regit's Avatar
Vehicle: 2000 tib
Thanks again..lil cutting,lil paint..voila.
