Guage light
Ok I did a search but came up empty.
Anyone know the part number for the lights that light up the dash guages(tach, speedometer, fuel, temp).
I feel that they are too dim and want to get brighter ones.
Thanks.
Thanks.
4 are 194's 2 are a bulb size I cannot find ANYWHERE. they are similar to 194's but about half the diameter, but the same length.
Originally posted by AzNxSandMan:
are the 194s the white lights on a stock 2001 tibby that light up the rpm and speed readings?
and the other two i'm guessing would be the turn signals?
No, there are 6 lights that light up the dash backround. 2 194's for the speedo. 2 194's for the tacho, and 2 of these small bastards I cannot find anywhere that light up the backround of the fuel/temp gauges.
Ah ic...I might pop in to my dealership tomarrow and ask about the small ones..
but I'm pretty sure they're getting sick of seeing me...
After I get this done I'm looking to get the blue needles from Import Intelligence.
Just wanna make sure. Are they compatible?
Originally posted by Big Lancer:
can some body tell me how do i get to that light in my car ihave no idea where it is at.. i want to color that bulb... because i want mine to be dim..
Which light is "That light"? do you mean the lights behind the gauges?
Yea i mean the light behind the gauge on the dash board... i want change the color to green how do i do that.. and how do i get to the light to change it.. ohyea.. does it work when you use finger nail polish on the bulb to change the color work... thanks
