EL Pedal Install?
Old Jul 30, 2001 | 06:21 AM
FluteMuffin's Avatar
Default EL Pedal Install?
I just recieved my Strut Bar and EL pedals this weekend, the bar went in fine as expected, but those pedals are a bitch to get on there!
They are on, but I would appreciate some advice on hooking up the power. The instructions say to hook it up to the same wire that runs the dome light/map lights... but I am really clueless as to where to do this?
Any information or shared experience would really help out! Thanks!
Old Jul 30, 2001 | 01:48 PM
When I hooked up bradleys, I cheated. He had Neons in the fenderwells set to go on with the Door being open.
The neon's were connected to the door switch. Pull the door plunger switch. Note the colored wires that it uses. Then remove the door sill cover and you should find that wiring. Trace it back to near the pedals to tap into it.
Warning...once you get those suckers on, it moves your Brake and Gas pedal really close together. More than once when I drove bradley's car I would hit the gas and brake at the same time.....
Old Jul 31, 2001 | 10:25 AM
Thanks Random,
Yeah, I have the pedals on (with no power to them) and noticed that the brake and gas are very close togeather. After a few days, I'm pretty much adjusted to it now. I had my g/f driving my car yesterday and she was holding the brake at a light and pressed the accel too, reved the engine up to 5k and suprised the guy next to us ;-)
Thanks for the info! Time to go hook those babies up!
Old Jul 31, 2001 | 06:11 PM
Xorro's Avatar
Vehicle: Mitsubishi Lancer Ralliart GSR
I have the Speed Glo pedals. I ran a wire off the back of the dome lights.
Old Jul 31, 2001 | 06:40 PM
[QUOTE]Originally posted by Zorro:
[QB]I have the Speed Glo pedals. I ran a wire off the back of the dome lights.
Zorro...what's that switch for that's halfway to the pedals?
Old Aug 1, 2001 | 06:51 PM
Xorro's Avatar
I knew someone would ask that!
It switches on my amp...but its redundant coz its not connected to anything anymore.
