El Gauges Not Working?
Old Mar 22, 2007 | 08:20 PM
aaronk19's Avatar
Hey guys, I put in some el glow gauges, they worked perfectly for a couple of days, looked great! However the other day i turned the car on, and they didn't light up. I checked the grounds, the gauges themselves, anyone got any ideas!?!?!
Old Mar 22, 2007 | 08:57 PM
TopSpeedFX's Avatar
Vehicle: 1997/Tiburon/FX
take them out and see if they work outside of the car with another electrical source. Then if not Id talk to the place you got them from.
Old Mar 22, 2007 | 11:33 PM
bad transfromer
Old Mar 27, 2007 | 05:55 PM
pauly's Avatar
QUOTE (aaronk19 @ Mar 22 2007, 09:20 PM)
i put gauges in my car also so make sure that if you had to connect them to a 12v power source if those are all connected then i have no clue man...lol sorry
Old Mar 27, 2007 | 08:43 PM
It's usually a bad transformer. But if you have the type that changes from blue to green, check the connections on the back of the switch. Alot of times they break because they're crappy and unprotected. Just look very closely and be careful because I've been zapped quite a few times trying to figure out where the little thing was mounted below my steering wheel. It hurts. I eventually moved it so it just bearly peeks out from under my dash.
