El Gauge Buzzing
So a while back I bought EL gauge overlays from ebay, they were for an Rd1 (which I didnt know when I ordered them) so I swapped my cluster with an Rd1, and now they work pretty well. By question is, how the hell do I eliminate the damn buzzing noise from the transformer? They have two colors, green and blue, and the green hum is slightly noticeable, but the blue hum is very annoying (and I happen to like the blue better). Any ideas?
there are different transformers you can buy aftermarket. I noticed the color switching transformer buzzes less then the normal on/off transformer. there is another more expensive type which i have yet to try that comes with a control panel. you can buy them on ebay, there is no reason to match the type of vehical you have. they are all the same.
If you'd like to go with a cheaper route, try mounting it with foam doublesided mounting tape and encase the whole transformer in it. it will provide a bit of shielding for the noise and cause the vibration to be dampend by mounting.
