Dash Lighting Question
Just took apart my dash because i wanted to change the color on some of the lighting, and change a few things. I'm wondering why these little bulbs (picture below) aren't lighting up. I put my little cheap fuse checker, that lights up if theres voltage, right into the positive side socket and its reviecing voltage. It looks like the ground is there too and the bulbs don't look burnt out. Theres 4 of these bulbs: 2 that light up the air conditioning cluster and 2 that go near the ciggarete lighter. None of them turn on when i turn the interior lights on. Whats going on? its gotta be something stupid.
http://imageshack.us/a/img833/7245/img0947m.jpg |
Where were they tucked away at? It appears above the head unit?
Originally Posted by majik
(Post 670680)
Yea those two little bulbs im holding light up the numbers on the fan speed and the hot/cold blue to red guage |
Originally Posted by hemmylane52
(Post 670676)
the bulbs don't look burnt out. None of them turn on when i turn the interior lights on. Those lights come on when the parking or headlights are turned on. Go get some new bulbs and at least try them. Or try a known good bulb from somewhere else to test with. If that doesn't work, then we'll start the troubleshooting |
Originally Posted by pas1216
(Post 670683)
Go get some new bulbs and at least try them. Or try a known good bulb from somewhere else to test with. If that doesn't work, then we'll start the troubleshooting Anyone know of the bulb type there? I dont see it written anywhere. It might be the bulbs cause theres a switch that uses the same power and ground wires as those bulbs. The switch controls whether the air blows from the back or front (i think), and the little light in that lights up... its just weird that all of them went bad when i decided to remove the dash? I think the ciggarette lighter bulbs where out for a long time though, so i guess its a little less weird lol. |
the local parts stores stock them, I replaced them in my Accent a while back. PITA to change
(Post 670694)
Alright, i'll just cut one off to bring in as a reference |
cut one off!? You mean pull the bulb out of the socket..... right? :Unsure2:
(Post 670733)
Yea, idk what i was posting... its a 2127 wedge bulb if anyone else needs to know |
