Changed guages, speedo no work!!!
I changed my guages to the silver Shark racing ones (VERY NICE) but my speedometer needle is not moving!!!!!!!!!!!!! Can anybody help me? Random? Anyone!!!??? I'm going to take it ALL back apart right now so I'll check back in a bit.....and , being that I'm terribly desperate, I'll post my phone # if anyone would like to call and help me =-) this is awful....hopefully it's something silly. 302-753-3735. Thanks everyone.
Okay, here's the deal.
Your speedo needle shouldn't be installed untill the key is in the ignition and the car turned on, but not running. (same with the Tacho needle)
Then install the speedo needle so that it LIGHTLY rests on the speedo rest pin, and press down on the "hub" of the needle with about 3-5 lbs of force. Any more than that and your speedo needle can go too deep.
Give this a try and lemme know if it works for you.
Tip....Leave the clear plastic cover off the gauges for the first week. This gives you a easy way of moving the needles to adjust them properly.
[ May 15, 2001: Message edited by: Random ]
Random, what you mean by leaving the clear plastic cover off the gauges for the first week? After a week and with proper adjustment we're suppose to apply the plastic cover back onto the face gauges?
There is a clear plastic cover over the gauges that prevents your hand from touching the gauges. Leave that part off while you are making sure you gauges are 100% correct. Once you are 100% positive that the Temp Gauge, Fuel gauge, Speedo, and Tacho are correct, you can re-install that clear plastic cover to protect the gauges and needles. Trust me. If it might save you from ripping your dash apart a couple of times (don't ask me how I know)
[ May 30, 2001: Message edited by: Random ]
[/QB]Trust me. If it might save you from ripping your dash apart a couple of times (don't ask me how I know)[/QB]
Oh I know, a royal pain in th'arse. I'd rather have a sharp stick in my eye
MiKE
