Buying A Car Alarm
Ok so I am looking to buy a car alarm with remote keyless entry and car starter.(car starter not as important.) Do you guys have any ideas on soom good ones to buy. Plus I hear i need some kind of relay for keyless entry
I have a 2001 tiburon
First you should decide how much you want to spend versus quality. There are some good units out there and some "not so good" units. I see your in PA, how close are you to Buffalo, NY. I can get you a deal on a compustar from Innovative tuning, I'm the installer there. For the 2W900FM-AS (alarm with remote start) unit I can install it for $400. Compustar is probably the best unit out there. As far as your locks, all 1st and 2nd gen tiburons don't have actuators in the drivers door, so one needs to be installed. If you don't want to go with a compustar, I would suggest getting any one of the DEI brand units.
2W900FM-AS
Up to 3000* feet of Range
This model was introduced during the first half of 2004. It has the largest LCD of any CompuStar remotes along with a built in clock. The 900MHz technology used in the 2WSS-Series was re-tooled for a longer battery life and a quicker response time between the transmitter and receiver. Firstech engineers were the first to perfect 900MHz FM for vehicle security applications.
*Range is quoted for U.S. models only. International models will differ in range.
Available in blue (2nd car) or gray (turbo) (Includes 1 x two-way remote and 1 x one-way remote)
Basic Remote Features
Two-way paging remote
Vibration and audible notification
Run-time indicator
Turbo timer or 2nd Car
CompuGlow backlight
Multi-color LCD (liquid crystal display)
Shock sensor on/off through remote
Passive on/off through remote
Valet mode on/off through remote
Uses standard AAA battery
Built in Clock
Largest LCD of any CompuStar remotes
2004 Innovation Award Winner
Basic Alarm/Start Features
Includes dual stage shock sensor
RPS (remote paging system)
External Siren (six-tone)
Super bright blue LED
2-auxillary outputs
Dedicated trunk output
Horn honk output
Includes anti-grind and starter-kill relay
Driver's priority unlock
Ignition controlled door locks
Trunk output
Remote start
Diesel features built-in
Manual transmission compatible
Run-time indicator
CompuGlow backlight
Built in Clock
2-auxillary outputs
Horn honk output
Trunk output
Remote start
I wanted to get a compustar but no one around here sells them, so I'll probably get a viper. has keyless. and isn't too expensive. I think it was 350 installed at a local place here with acuator and some other sensor upgrades (I think it was a remote sensor rather than just a built in one.)
