Blower Problem. Any Tips?
Old Jan 21, 2006 | 12:09 AM
gthaman's Avatar
I started my car this morning, and it was quite chilly, -7C. The blower usually starts, and I go out to scrape the car for ice. But, when I was done and went in the car, I noticed that it was not blowing! It was set to 4, the AC green light was on, the heat was on max. But no blowing. What can have happend? And tips? My car is virtually undrivable because there will be to much damp on the inside when I drive... I can't see shit. Help is needed fast... sad.gif
Old Jan 21, 2006 | 01:32 AM
check fuses. most likely that's what it is.
something might be causing your fan to stop moving. If the fuse blows twice, then check your blower motor for debris.
Old Jan 21, 2006 | 02:18 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I'm 90% sure that it's your fuse. Do not forget to choose fuses under the hood as well.
Old Jan 21, 2006 | 09:58 PM
BLK2KTIB's Avatar
I doubt its a fuse, either blower motor relay or blower motor itself.
Old Jan 22, 2006 | 09:30 PM
dude, go out to your car with a pair of pliers and pull some fuses and look at them. it's not that hard mang. I posted the entire troubleshooting steps already. If you can't check item #1, then take your car to the shop and get raped for them to change a fuse and tell you "we had the blower motor in stock and we put it in there in just 20 minutes". go, get raped, or check a couple fuses, your choice man.
Old Jan 29, 2006 | 11:00 PM
gthaman's Avatar
I checked the engine fuse, I was fine. Ive just been on vacation, and I havent had time to check the other one yet. No 16 you say. Which one is it? Any pic?
Old Jan 31, 2006 | 09:06 PM
by your left foot when you sit in the driver's seat. it should be labeled.
