Angeleyez wire setup #2 help please!!
Re: OZ-BBTB
hey guys... im in a rut. im not sure if this is the right forum... but i have the angel eyes wire set 2 and im a noob with wiring.
i need help please.. what do i connect to what?
ill throw up pictures of the wires i have in a sec
Re: Wheel choice advice...
i would use the corner lights for ground. simply crimp both ground wires onto the black wires coming out of the corners.
plug the angel eyes into the power wire for both. run that wire through the firewall and into the cabin(check the diy section for some help). connect that wire to the switch(doesnt matter which side, just switch the sides if one is the switch is labeled on and off and you get it wrong). then chris says to run the other power wire back to the battery, but i dont think thats really necessary. leds take up almost 0 power. i would just connect the (i think its yellow?) power wire with the red/blue wire coming off the headlight switch. if there isnt one, then it is the red/black wire. wink.gif
Re: OZ-BBTB
ok.. here are all the wires
more pics..
closeup of both ends of one wire.. now wtf is that extra piece without anything on it?
another pic
ok so basically i have the two sets of wires fro the headlight haloz... two sets of (two ground wires twisted into one), and two sets of (two power wires twisted into one)
please tell me which to hook up next and so on.. i know how to get it through the firewall( i think) i read a post on where i can do that. THANKS GUYS!
*DON'T DOUBLE POST*
eh thanks tibby.. do you think you could show me with my pics please?
so i can just cut the corner light wires and clamp the grounds on? do i use both of those wires with the blue clamps for the grounds? for example, take the left headlight grounds, crimp them into one of the wires witht he blue clips, and then clip the blue clip onto the left side corner light? and then do the same for the right headlight?
*DON'T TRIPLE POST EITHER MANG< USE THE DAMNED EDIT BUTTON!!!
*and you said im grounding them on the corner lights.. but where do i attach the switch's ground wire?
more pics..
another pic
*DON'T DOUBLE POST*
QUOTE (97supalude)
Re: OZ-BBTB
Doode, use the edit button, don't double or triple post man.
Also, your sig is just one line too long.
LOL
It's on the homepage for the site mang.
LOL
Re: Got Chat ??
ah mah bad..... sorry about that. and your shitting me on the sig right??? yeah ill assume you are. laugh.gif
ok thanks for that but where do i connect the black wire on the switch??? to the battery? its ground right? can i ground it anywherE?
Vehicle: 2000 Tiburon
Re: Kspec Maintec Header/Turbo Manifold GB *10/27 UPDATE*
Ok, and since someone is bound to ask without checking www.haloz.biz here goes the pics/info for wiring set #3...
Re: Rear bucket seats
QUOTE (Dweet)
i grounded mine to the battery
you grounded the switches ground to the battery or the lighjts grounds?im still not sure where to connect the switch ground
Re: I can't access to this site from my home computer.
its not a switch ground.
think of the switch as a damn. when its open, the water(electricity) can go through. whe it is closed, the electricity cant. thats all this switch is acting as, a valve to allow electricity through. that switch has two power wires going into, and out of it. one is connected to a power source, the other is connected to the angel eyes. so one wire should be coming from the battery's positive terminal(or some other power source that is on when you need it to be). conenct that to one side of the switch. then run another power wire form the other switch terminal to the angel eyes's power wire. finally, run the grounds.
