Amp Power Cable/s?
Old Jun 15, 2010 | 11:49 PM
03AccentVA's Avatar
Vehicle: 2003 Hyundai Accent
Default Amp Power Cable/s?
Hey guys, long time!! Quick question. I just upgraded to a 600W amp from 340W and realized my power cable is to small. While I was troubleshooting the old amp I bought a new cable kit. Problem is neither old or new is a large enough gauge to support the new amp. Along with that, the one that is large enough is too big to be tucked away and about $30/$40 at walmart [more at the auto audio shops].
Question is can I run two smaller gauge wires in tandem with smaller fuses or would it be better to bite the bullet and go with the large gauge?
Also what's a good fuse sixe for a 600W?
Thanks!
Old Jun 16, 2010 | 07:31 AM
flipmatic's Avatar
Vehicle: '99 Accent
I think you should bite the bullet and get a bigger power cable. If you dont want to buy a whole kit just go to a local stereo shop and buy a few feet of bigger cable alone. Should only be a few dollars.
Old Jun 16, 2010 | 10:52 AM
Running 2 wires would technically work, but is not a good idea.
Just run some 4ga. wire. It's what I was running in the Accent all tucked out of sight and it'll power your 600w amp.
Old Jun 18, 2010 | 10:54 AM
00sharkbmr's Avatar
Vehicle: 99 hyundai tiburon
QUOTE (187sks @ Jun 16 2010, 12:52 PM)
I bought 6 gauge wire at Lowes. you can buy it by the ft
Old Jun 18, 2010 | 12:19 PM
Amp should have a recommended fuse size
Old Jun 18, 2010 | 09:26 PM
bdiggy's Avatar
I run my 1000w Memphis on 4ga all day. You'll be just fine with that and still have more room to upgrade.
