Alarm And Actuators!
I have an Autopage RF-520LCD that i just installed today (changed from the 310) and so far everything works that i have hooked up cept the Door locks. I added an actuator to the drivers door of the 2-Wire type and hooked it up just as the alarm manual states but they do not work. Now the actuators came with a Relay that i did not use. So im not sure if thats the problem or not. If anyone has any suggestions at all it would be much appreciated so i can get this all buttoned down and start the door popper install next. Thanks
you have to use that relay. the alarm outputs for the door locks usually can only supply 150mA. actuators need a lot more current than that to operate. that 150mA from the alarm brain is used to switch a relay, which can then feed a higher power source to the actuator.
